Timez Attack bad executable trying to launch the program
Hi there,
Late this evening this error appeared. I never had an error before caused by Timez and now it started to appear more often. The reinstall is not helping and System Restore too. Can anyone help me please to fix this error ? What is causing this one ?
Thanks !
There has been an error.
Error running C:TimezAttack/TimezAttack.app/TimesAttack.exe : child killed: SIGABRT
The application will exit now.
OK
Answered By 590495 points N/A #178398
I don’t think it is a compatibility issue because it supports the modern version of Microsoft Windows as well as Mac OS X. If you are using an old version, download the latest version, Timez Attack for Windows and Mac. For Microsoft Windows, it supports Windows XP, Windows Vista, Windows 7, and Windows 8. For Mac, it supports Mac OS X 10.6 Snow Leopard.
Once downloaded, uninstall your current application then click Start, All Programs, Accessories, System Tools, and then click Disk Cleanup. Select drive C and click OK. Check “Temporary files” and “Setup log”, click OK, and then click Delete Files. Restart your computer and then run the installer you just downloaded. If the problem continues, try starting the program as administrator.
Right-click on the Timez Attack shortcut on your desktop and then select Properties. Select Compatibility tab and then check “Run this program as an administrator” under “Privilege level” section then click OK. Start the application again and see if it works. The application requires 128 MB video RAM and higher but may also work on video cards with 32 MB video RAM.
If you still experience random program crashing or shows unusual display, you should update your video card’s driver. For Intel graphics adapter, visit Intel Driver Update Utility Graphics. For ATI graphics adapter, visit AMD Graphics Drivers and Software. For NVIDIA graphics adapter, visit NVIDIA Driver Downloads.
