Tiny, LINUX-powered PCs invading the market
LINUX is trying to be flexible across an array of all different devices coming out on all sizes, shapes and functionalities. These tiny PCs are believed to be the mark of the POST PC Era. But will this device even come close to doing just that?
Home PCs may be bigger in size and if the world is getting small and a tiny PC is to replace them, and then it has to have the same functionality that would go along with its size. Let's check the specifications of these units and see if they can live up to the expectations of a home PC. These tiny units should also be able to run more applications than its predecessor.
Has someone checked if this device is rootable?
