Tips for coding CSS Outlook menu
Honestly, I'm not a pro in web design, particularly with CSS. I just want to learn how to use CSS to improve my skills on web development.  The MS Outlook menu seems to be a good design for a personal website that I'm building. Could you please give me tips for coding css outlook menu?
Best Answer by Algren Nathan
Answered By 0 points N/A #194949
Dear Paul,
For coding css outlook menu at first you have to decide which part of menu you want to code. There are so many codes for different tasks in outlook menu. You have to also mention about the version of outlook. You can add a button or you can add a dropdown menu or a context menu or a nav menu or can change the style of a menu. So it’s hard to describe all here. You have to mention what code you actually need.
Thanks for asking.
Answered By 0 points N/A #194950
Best tips for coding CSS are ;
Build your Emails with tables and gifs,
No background images, only back ground colors should be used for best results.
Use decent and basic style,
Don’t use padding, only margins.
Keep your code as simple as possible.
Optimize your emails for “image off” mode.
And always test your email by sending it to your self for best results.
