Tips on Creating a Report for Free Sample Event
What are the important points to consider while creating a report for a free sample event and which are  the points I should stay away while creating the report?
In common sense reports are for more detail view of the data. Reports are most often used by the management of a company. So they don’t want the do the calculations and counting of the data available and they just want to use a good explanation of data in first site.
When creating reports.
Be specific and clear on the content.
Include detail information but with clear format.
Show separation of different data.
Consider spacing and margins of the report.
Use graphical content as much as possible.
Avoid using more fancy stuff.
Look of the report must be attractive.
Add option to import the report in several formats (Ex: PDF, MS Word, MS Excel)Â
