Tips in enhancing the security using the VPN Tunnel
I'm currently using the VPN tunnel, should I also use SSH and other "high layer" encrypted services?
Hy,
You can increase your VPN ‘s security system easily and its so important  too. The VPN become popular since few years. You should be buy the subscription for the VPN and then you will able to use the security feature of the VPN.
You can use the VPNCheck for keep your VPN safe form the break of connection and you can stop the leaks of DNS for extra security.
If you want to know more about the security of your VPN then you can contact with your VPN service providers. They will take attention to enhance your VPN security.
Thanks
Hi Gin,
With a view to enhancing the security you can try these. Download VPNetMon to watch your PC's ip addresses. You can download the VPNcheck.
It assists to be safe at the time of breakage of VPN connection. stop DNS leaks. Fix the PPTP.
Use only those VPN providers who can take care seriously about your privacy.
