Mark Leslie
20 points
Posted on - 06/16/2012
I have a Photo Printing business. I edit some ones pictures and print them.
I wanted to know how to save ink whenever I edit pictures with Adobe Photoshop?
Do I need to fix my Adobe Photoshop settings?
rajibh
Tips how to save Ink when printing with Photoshop
For easy way I learned about InkSaver 2.0. This software has been around for several years and it can really help you and Photoshop well supported. It allows me to control the amount of ink used by my inkjet printer, making my ink cartridges last longer.
InkSaver 2.0 uses special software algorithms to optimize printer data so that your printer uses less ink – even when printing at your inkjet's highest resolution. Once you setup InkSaver, you can forget about it because it works behind the scenes.
I have found it to be the best way to save ink while maintaining high print quality.
Sometimes you need to fix your Adobe Photoshop settings? (optional)
