Tips in preparing for Cisco interview on Java, SQL, and other topics
I am applying for a programmer in Cisco Systems. Can you send me tips in preparing for Cisco interview on Java, SQL, and other topics?
On Cisco interviews normally what they ask is what you did on your former employer as a Cisco engineer, what where the common problems you encountered and how you fixed it. they will also give you several scenarios & will ask you to fix the problem they provide all in verbal explanation.
If you are doing to be in an entry level position as a Cisco engineer.
These questions maybe asked,
How do you setup a Cisco managed switch to have vlans in a given port to provide two or more separate LAN connections for different offices. and making sure they do not see each other but can access the same server?
how can you setup a dual channel network using a Cisco core switch to allow one office to have two fiber optic babbles as its backbone simultaneously?
I hope this helps
Thank you
Notifications
