I am new to playing Titanfall on PC. However, I can't seem to play it as it always throws an error "Disconnect: ORIGIN error retrieving player data from storage – code 503". Titanfall needs firm Internet connection to play the game, yet it seems that I could not connect. How can I be able to resolve this issue? Please help me.
Titanfall Disconnect Error Code 503
You are not alone! This becomes a major problem for the past few days and Respawn (Titanfall Developer) acknowledged all the issues and they are now working on fixing them all. They also investigates to resolve all the problems associated with Titanfall.
Error code 503 means, a server is temporarily unavailable or its overloaded. So, we cannot do something about it since it's a server side issue. As of March 12, 2014, according to EA, Titanfall connectivity issue has been resolved. But if you are still encountering Error 503, try to do the following:
1. If your Internet connections are exceedingly slow, this will create an error on joining to a server or play the game. Some may also encounter infinite loop when attempting to connect.
2. Try to reset your router or your modem by simply unplugging them from its outlet for at least 15-sec. And then re-plug it back again.
3. Restart the game.
4. Contact EA Support Team and inform them that you are still facing connectivity issues.
For more issues on playing Titanfall Origin, click the link below:
Titanfall known issues and troubleshooting information
