Arzikie
Posted on - 08/08/2011
hi there, i need to make a good decision on what laptop to get for my work. im a graphics person. i'd need a laptop that can effortlessly multi-task heavy work, one that can seemlessly handle video editing, graphics design, and has long battery life for up to 6.5 hours in heavy use. aside the Macbook pro, is there any other – how about the HP elitebook? what the real down side of the Dell 15z?
deandre
A ‘lite’ laptop for intense use!
Hello Arzikies, Good to know that you are a graphic type of person, a more choosy in terms of specification of a product. I too, sometimes need good type of equipment, appliances and gadgets that do multi-task. Here are my suggestions to build perfect multi-task, high quality of graphic design and video editing computer; 1. Core i5 2.3 GHz – 13.3″ – 4 GB Ram – 320 GB HDD 2. G7-1070us – Core i3 2.53 GHz – 17.3″ – 4 GB Ram – 500 GB HDD 3. R835-P56X – Core i5 2.3 GHz – 13.3″ – 4 GB Ram – 640 GB HDD You may also need to custom built your computer to get and install highest specification of components such as Hard Drive, Ram and VGA card. This will definitely enhanced the clarity of video. These are one for the best specification pefect for your needs.
