Title-ifc22 Dll Download Error While Running A Software
Yesterday, I tried to install HFSS software for antenna designing. After the downloading, and complete the installation, the following displayed. Help me to figure it out.
![](https://www.techyv.com/sites/default/users/Images-Folder/ifc22-300x109.png)
The following steps are required-
HFSS stands for “High-Frequency Structure Simulator”. It is a commercial finite element method solver for electromagnetic structures developed by Ansys. It is one of several tools used for antenna design and designing complicated RF electronic circuit elements including filters, packaging, and transmission lines. If installing HFSS triggers a missing “ifc22.dll” file error, check that your computer meets the requirements especially the video card.
HFSS supports 64-bit Windows 7 and Windows 10 including RedHat/SUSE Linux. It requires one to two processors (1 – 2 processors) with four to twelve physical cores each (4 – 12 individual cores), 16 GB RAM, 2 TB free space, and a compatible video card. For the list of compatible video cards, see Supported Graphics Cards. That “ifc22.dll” file error might be referring to your video card.
It is either your video card is not supported or you need to update its driver to the latest.
