TLF text only support in Flash Player 10 or higher
Hi all,
I have been using the Adobe Flash Player for quite long time in never faced this error message in the past. When I am using the TLF text in Flash Player 10, I got this weird error message. I am not aware of this error, please suggest me some solutions to fix the problem. Thanks a lot.
TLF text can only be supported in Flash Player 10 or higher. TLF text will be permanently converted to classic text if the current publish settings are changed. There is no undo for this operation.
