To add weather gadgets for windows 7 in PC
How can I use weather gadgets for windows 7 in my PC as it would be easy for me to track the temperature and more of the city. Thanks in advance for the help.
Hi! I’ll guide you step by step on how to set up weather gadgets for windows 7 as it is very simple to use them.
Step(i) Right-click on your desktop. You should see a menu similar to the picture below.
Step(ii) Select Gadgets.
Step(iii) Right-click on the weather gadget and select Add.
Step(iv) Your Weather gadget should be on your desktop.
Step(v) To change the location to your current location click on the tool(options). Insert your zip code, click on the magnifying glass (search), and then click OK.
I hope you have understood the steps well.
