I have windows 7 installed on my computer but I am unable to find the settings where I can change the desktop theme for windows 7 and also the slide show option for images. Anyone, please guide me with the steps.
To change the desktop theme for windows 7 step by
Hi! I am a computer geek and will guide you on how to change the desktop theme for windows 7.
Step(i) To change the appearance right-click an empty area on the desktop and select Personalize.
Step(ii) To change the background click on the desktop background as shown –
Step(iii) After that the window will appear which has different options for changes.
Also, you can change the sound of the background as-
Step(i) Click on the button as shown in the image.
Step(ii) Here you can go through different sound schemes and see how they will sound for different program events like logon, system notifications, low battery alarm, and more.
If you end up with a theme you like you can save it under the My Themes category.
