To create windows server 2012 r2 System Restore by command line
How to Perform Windows Server 2012 r2 System Restore Using Command-Line and Why use the command line to do a system restore?
The Command line is easy to use even you are not within windows.
In Windows Server, system restore is a great utility to roll back the system to the previous state if any emergency happens to the system. You can run the system restore from inside Windows with Recovery Wizard, or you can run Windows Server 2012 r2 System Restore with the command line.
Command Prompt is available on every Windows NT-based operating system, which includes Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP, Windows 2000, as well as Windows Server 2012/2008/2003.
Sometimes, however, a problem is so bad that your computer won’t normally start, meaning you can’t run System Restore from inside Windows. Fortunately, even if all you can do is use it  in Safe Mode and access Command Prompt, you can start the System Restore by executing a simple command. Also, using the command line is more convenient for batch files and batch commands.
