Sir, I tried to add an active directory module for Windows PowerShell in Windows 7, but was not successful. Can you please just tell me what steps I should follow to ensure my installation?
To Deal With Active Directory Module For Windows PowerShell Window 7 Of Your System.
Yes, You just have to follow some simple steps before installing a Power shell script. First of all you must be knowing that you can’t import active directory for Windows 7 so, download the Remote Server Administration Tools (RSAT). After installing it, go to the control panel and search for features when you see the aspects just click on ‘Turn Windows features on or off’. Now look for Remote Server Administration Tools in it and then enable Active Directory Module for PowerShell Windows 7.
Or you can go to the Administrative tools in control panel. Or in the above one you just have to go to Remote Server Administration Tools also check box Role Administration Tools and then active directory module Tools.
