To Help Identify A Top 5 Network Monitoring Tools
How does network management work? If my mail connection is timed out, is it a network problem? Is my company in need of a network monitoring tool? What are the top 5 network monitoring tools?
Network monitoring is done to identify whether or not a server is crashed or overloaded, or whether there is any form of network mismanagement. For example, if a test message is sent via SMTP and there is any form of delay or if there is a connection time out, then a warning message, in the form of an SMS or any other can be sent to the system admin. So to sum up, yes, such a situation is handled by the network manager.
Your company might need a network management tool if your IT architecture is expanding and the problems due to network mismanagement are increasing.
Your company will benefit from a tool like above because it saves precious time for the company by analyzing and finding out where exactly your network lags and that might help you to put extra hardware at that particular pin point.
The five best network management tools are as follows (Not in any order):
1) Zenoss –Cross platform monitoring; Lacks integration with other database systems
2) GroundWork-Amalgam of other software elements such as Icinga or Nagois make it a powerful system to use.
3) Monitis-For small and medium sized companies
4) Icinga-Comes from Nagois core and it can be integrated with many databases
5) Pandora FMS-Perfect for larger environments, capable of monitoring over 10000 nodes and covers.
