To Make The Grammar Better, Check For Grammatical Errors
I am facing the grammar issues in my writing, so I want to solve it either online or offline so, what are the methods available to check for grammatical errors?
To better the English proficiency, the grammar is must better to correct the grammar, there are various methods that are available are given below:
Steps to check for grammatical errors:
Method 1:
1. First, open the MS word.
2. Then click on the review tab and select the Spelling & Grammar.
3. Word will offer the suggestion also so; you can click on the suggestion and then press the change button.
4. Click on ok.
Method 2:
1. You can download the Grammarly software as well as Grammarly Extension for chrome.
2. Go to the official site of Grammarly and download the software.
3. For the chrome extension, goto the extension store, and there you can add the extension.
Notifications
