To Unblock Hotmail Email In Windows
I have some senders in windows live Hotmail whom I have blocked previously because of some reason. But now I want to unblock them. How to unblock Hotmail email in windows?
To unblock Hotmail email in Windows, you need to follow the following steps:
1. Go to Windows live Hotmail toolbar and select options from there.
2. Under preventing junk email option, you will get the safe and blocked senders link.
3. Click on block senders.
4. Then following this highlight the address you want to remove from list. And then click on remove from list.
Windows Live Hotmail allows you to filter out messages by adding or deleting email addresses or domains on the Blocked Senders list to manage the contents of your inbox. If you accidentally blocked an email address or you decided to unblock several email addresses whom you blocked before, here’s how to do it. First, you need to sign in to your Hotmail account.
To sign in, go to the Microsoft Account Sign in page and log in with your Hotmail account. Once you’re logged in, on your inbox, click “Options” then “More options” to open the Hotmail Options pane. Next, under “Preventing Junk Email” section, click “Save and blocked senders” then “Blocked Senders”. In the “Blocked Senders” pane, scroll down and select the email address you want to unblock.
Lastly, click “Remove from list” to remove the email address from the list and that’s it.
