Hi Friends,
TomTom Visual Studio Merge Module got installed in my system without my knowledge/permission, It is not getting removed even after when I uninstalled TomTom Home. Please advice on whether I can remove it manually along with all its supporting files.
Thanks,
Brady Collins
Tom Tom Home Visual Studio Merge module is part of installation of Tom Tom Home. It serves the purpose of making Home function as it should.
If you want to remove it from your computer due to the space (1.86 MB) it is occupying, either download a software “Should I remove it?” from Internet or Go to Windows Control Panel > Add/Remove programs > Select Tom Tom Module > Uninstall.
