This is my IT Question, While I'm browsing the net with Internet Explorer an endless amount of tabs start opening, starting one after another. To close this I have to close Internet Explorer manually from Window Task Manager and click on End Task. When I attempt to do this, my computer freezes. It is so irritating that I want to pull the plug of my computer!
I am genuinely concerned about this problem and I will be thankful for any solutions.
lee hung
75 points
Too many pop ups on my Internet Explorer
I think what your talking about is pop-ups. Meaning it opens immediately while you are using the internet browser without permission to the owner to open those sites. I experienced this problem five years ago and what i did is to reformat my PC and start a new OS, i just back up my files and start again and again.
Solution:
Install new Browser from the Internet
Internet Explorer
Mozilla Firefox
Google Chrome
MSN
Opera
In terms with hanging problem. Run your anti virus scanner to fix the problem.
Locate the viruses that causes lag.
Heal them all
Put the vault if the file is infected files
INSTALL DEEPFREEZE NEXT TIME for you additional protection on your PC.
Thanks,
Tony Stevenson
These pop up messages comes form either by viewing a specific website or by the network admin. You can check both cases and you will be able to solve your problem. You can check you network services and then you can change your settings also. Turn off pop up blocker form the internet explorer and make sure that you are safe. You can turn on or off pop up blocker by going to tools and then to pop-up blocker and then you need to disable your pop-up blocker from there and you will not get any error in feature. If the problem remain then you can upgrade your IE to solve your problem.
