Tool for Finding Old Security Groups
A lot of tools are available in finding old users and machine accounts in Active Directory, but I think it is even harder to develop a tool for finding old security groups. I can see that using the tool would make you scan the entire file servers so as you can compile a database of used groups then compare it against Active Directory to see if there are still remaining unused groups. Nonetheless this is still the tool that my company could use. Does anyone know a tool similar to this?
Answered By 0 points N/A #100468
Hello Friend.
You got the old users machine active directory. There you have to use some different soft and program for details. Restricted profile and lock hide program you also find from old user. Directory can serve various terms from installing
Yes you can compile your groups. Groups can spread by team view or other related software. Then you will get the similar of your question.
Next, your old system recycles and saved file would exist but could not perform properly. Then you break the code of system hard drive. But unused tools cannot describe you clearly as you browse or will get information.
Good Luck!!
