Tool gen report use php MySQL
I have a task to create a huge amount of MySQL reports. Please send me tool gen report use PHP MySQL.
Please help me by resolving this issue. Thanks.Â
Tracey David
Tracey David
Hi, Tracey David
As you know, from Google you can find a lot of forums but the chance of getting the right solution depends on where you post your problems. We have so many different forums to get tools to generate report using PHP MySQL.
So classifying and posting them on relevant forums is the best way to get your answer step by step.
I can suggest you some good forums, which are listed below:
1. Mysql Php Graphical Reporting Tool Downloads
2. Mysql Php Report Writer Downloads
