Tool to run Vbscript using online portal
Hello Techyv Friends,
I don’t have Visual Basic software neither there is an MS Office in my system, and I need to test a VBscript coding,
Please advise whether there is any tool to run VBscript with the help of any online portal, Please advise how to process the same.
Thanks and Regards,
Tomee Llman
Answered By 5 points N/A #156188
Hello Tomee
In this case, you can try an online VBScript compiler. Unfortunately it does not have a debug function so if your code is wrong or something is not well wrote you can not know what it is.
I have provided you with a link. Access it, enter your code and run it through the portal.
VBScript Online
I hope you will find this information useful.
Randolph
