Tool for sdhc files recovery
If I will format corrupted SDHC Card, I will lost my files there. Can you suggest the way or a tool for SDHC files recovery?
Hello.
After a good research I found some websites providing different tools to recover files from corrupted SD Cards.
But this software “USB DISK SECURITY” is the software for you.
Download the software and install it on your system.
After installation run the USB Disk Security and insert your corrupted card into the system.
USB Disk Security automatically detects the corrupted files and deletes them.
Then you may copy your files into the system and format the card by normal process.
Thank you.
In any media as in a normal hard drive, recovering files after it has been formatted is not guaranteed. Sometimes or most of the time, recovered files still doesn’t work and remains corrupted even after the recovery. If you already formatted your memory card, you can still recover the files inside using the usual file recovery tools available.
One you can try is PC Tools Performance Toolkit. Though the main use of this utility is to speedup the computer, it includes a file recovery function accessed via Recovery tab and selecting Recover Lost Files option. You can use this option to recover deleted files on your memory card but still it doesn’t guarantee the successfulness of the recovery. See image.
For those who are not yet aware, PC Tools Performance Toolkit was already retired effective December 4, 2013 and will no longer support any new updates. The company was already purchased by Symantec on October 6, 2008 for $262,000,000.
