Toolbar of display manager for Lenovo not showing properly.
Asked By 100 points N/A Posted on -
Recently I installed display manager for Lenovo on my Lenovo laptop.
Everything is working fine, but I can’t access all features from the toolbar.
Why isn’t it showing all features?
Any kind of help would be appreciated.
Best Answer by Jeany Math
Answered By 0 points N/A #133758
You can check your settings to see if your toolbar is enabled by following this simple steps.
  • Go to the wrench tool and click.
  • Look for tools and click the extensions.
  • Page will open and you will see those tools. If it's disabled put cursor to the checkbox to enable.
  • Refresh your windows and try to open the tab again.
Answered By 0 points N/A #196455
You need to download the perfect toolbar which will manage your downloads files, displayed as a bar. You can easily establish the criteria to determine the every type of file to be downloaded. This toolbar is merged with the web browser so that you could avoid the high consumption of resources.
Download the Toggle DU Toolbar:
http://www.downloadcollection.com/toggledu_toolbar.htm
