Toolbar moving problem in Word 2007
I have been using Microsoft Word 2007, here everything is nice but my problem is a Quick Access toolbar, for getting working advantage I need to move another place from the default place.
Have any suggestion that I can apply to move my expected area?
Best Answer by Johnyboy
Answered By 0 points N/A #125776
Hi Hafiz,
Yes, there is a way to move the Quick Access Toolbar to a different location though the places you can move the Quick Access Toolbar to be very limited.
The quick and easy way to move the Quick Access Toolbar is to:
  • Click on the on the arrow pointing down that is right beside the Quick Access Toolbar.
  • Upon clicking a dropdown box will appear, simply click on show below the ribbon to transfer its location.
  • The long way of doing this is to click on the Office Button that is at the top left hand corner of the program, click on Word Options from the resulting drop down box, click on Customize, then at the bottom of the page there is a checkbox Show Access Toolbar below the Ribbon, simply check this checkbox and your Quick Access Toolbar will transfer below your quick ribbon. T
There is no other place you can transfer your Quick Access Toolbar aside from here.
Hope this helps.
Answered By 0 points N/A #125777
On the tools menu, find a customize button and try to select the toolbar.
Follow the attachment please.
