ort erik
Posted on - 10/05/2012
I am using php script convert avi to mp4 over the internet but the speeds are so low and it takes alot of space, can anyone out there post for me some link where i can find some external tools that can be invoked via php script for greater speeds.
Tools that can be invoked via php script convert avi to mp4
Hallo Ort,
If the internet is slow then you will just need to troubleshoot the problems with the internet connection to be able to successfully use the php script to convert avi to mp4. That a file that needs a lot of bandwidth to buffer and therefore whichever link you use, it will require that you have strong internet connection.
Nicke
Hello Ort Erik,
If you are having problem converting videos from avi to mp4 over the internet because the speed is slow, then I suggest you a software that you can use for the conversion process. The name of the software is "flvtoavi", it converts between many formats including avi and mp4. It is a free, very light, easy to use software with quick conversion speed. The download link is www.flvtoavi.com
I hope you try this out and it solves your problem.
