jibonkhan
Posted on - 07/26/2016
I am looking for a tool that can compare word documents for differences both online and offline and can also work on any device, including desktops, mobiles, tablets, etc. Can anybody recommend any such tool?
Tools To Compare Word Document For Differences!
Workshare Compare is one such tool that you are looking for, and which provides us the most accurate results. You can easily compare two word document versions and quickly find the differences between them without any much struggle on the technical part. It also lets you integrate with Outlook that allows comparison between attachments also. It is available both online and offline and supports all devices.
Moreover, you can also take a free trial on its official website:
www.workshare.com
