Tools that help monitoring the size of your mailbox in outlook
What are the tools that will change the size of mailbox in outlook if you need more space? Does these tools exist?
You can increase the Outlook mailbox size through the following ways. You can see here how to see your present mailbox size.
Via Registry:
Step 1: Open Registry Editor
Start > Run > regedit
The default location for registry editor: "C:Windowsregedit.exe"
Step 2: Locate the Key:
Browse the folder tree to locate the key:-
Outlook 2003Â
"HKEY_CURRENT_USERSoftwareMicrosoftOffice11.0OutlookPST"
Outlook 2007Â
"HKEY_CURRENT_USERSoftwareMicrosoftOffice12.0OutlookPST"
Outlook 2010Â
"HKEY_CURRENT_USERSoftwareMicrosoftOffice14.0OutlookPST"
Step 3: Create and set 2 new DWORD values
WarnLargeFileSizeÂ
Don’t set this higher than "4090445042" (decimal) or "f3cf3cf2" (hexadecimal)
MaxLargeFileSizeÂ
Don’t set this higher than "4294967295" (decimal) or "ffffffff" (hexadecimal)
The difference between the two values should be at least 5%.
