I'm using blogger.com as host of my long-time running blog. I want to block readers from my country from viewing my blog, and I found out that toolator is one of the tools that I can use. The only problem is it can only block 3 ip addresses. I want my whole country to be blocked. Is there any other tools aside from toolator that can block Ip addresses from my country?
Add An IP-Address Locked!
Your privilege to add more ip-address has been disabled. This is because your account-type doesn't allow to add more. Upgrade your account to add more ip-addresses.
From toolator
Peter123
Tools that I can use in blocking IP Address
Hi!
Keeping our website away from the un-wanted clicks is the most important thing specially while using Google AdSense or any other referral programs. You can use many different tools for this task like iptable or htaaccess with some complex syntax but the most easiest way to block a particular IP is to use firewall. By which you can wither block a single IP or you can block a full range of domain.
I suggest you to search for your firewall settings and try to block a full domain.
Hope it helps.
In order to block all IP addresses from your country, you should create a database table for IP ranges and then checking the IP addresses of the visitor in the database. If it is found there you can deny access and hide your blog. To get the IP range of your country, visit the site http://www.ipaddresslocation.org. Here you can get IP address range of your country in the form of text file. You can import it into your database table. You should have basic knowledge of PHP or you can take the help of any PHP programmer.
