Tools for installation of multi version IE on 7
10 points
Posted on - 12/06/2012
I'm about to start my testing of a particular web application that I developed for a friend. I wanna test the apps in multi version IE on 7 since we (I and my friend) are using Windows 7. Could you suggest tools that allow installation of multi version IE on 7? Thanks.
