Tools for mounting iPad in the wall
I would like to mount my iPad on the wall in such a way that it can be easily detach if I want to. I want to hide those cables too. What do I need to buy to perform this? Thanks.
Its very easy to mount an iPad on a wall using a wall mount disk and an iPad cover. Just fit the wall mount disk to wall and then put iPad a cover which have a hole in it where you could fit the wall mount disk to it . So, its very easy to mount it but no way to keep the cables hidden. Many products are there for this purpose, but i suggest you wallee. They also have a lot of products that help to carry iPad, use from car, office etc. For more details just go to the following website.
Hope this information helped you.
Triclers Frost
Notifications
