lowry zender 10 points N/APosted on - 06/30/2017
I am looking for tools on how to convert docx to jpeg online. I have tried downloading some softwares for the purpose but mostly I found make with them. That’s why I am looking for some online tool that help me convert.
It is a really good website as it helps you convert word documents to picture format without any hassle and in good quality as compared to other converters and it is one of the most used converter websites available online. You just have to browse and select the files and then hit on convert and let the process complete. You can also do multiple conversions in one go and also upload files upto 50 MB in size.
Converting an Office Word document file (*.docx) into JPEG would be easy. You don’t need to install any software to do the job. You simply need to upload the file, adjust the quality of the output image, convert it, and then download it, that easy. You also don’t need to provide an email address like other online converters where the converted file will be sent.
You immediately download the file once the conversion is complete. Visit DOC to JPG – Word to JPG Online. Here, click “SELECT WORD FILE” then select the Office Word document file you want to convert.
Select and upload DOCX file
This will automatically upload your DOC or DOCX file. Next, select the output format of the image. You can select between four output formats: JPG, PNG, GIF, and BMP. You can also adjust the quality of the output image. Default is set to 50.
Select output format
When you are ready to convert, click “CONVERT” then wait until the conversion is complete.
Convert the file
Once it is complete, it will prompt you to download the file. The converted file is in ZIP format by default. You need a file extractor to unpack the file and open your image files. Right-click “Download Zip” and select “Save link as” to download the file to your computer.
Download the output file
And that’s it. You can use 7-Zip to unpack the ZIP file.
1....
