Tools for open nokia backup file in PC
I have a 16 GB Nokia Lumia 800 with 1.4 GHz Scorpion CPU and OS Mango 7.5. Are there any programs or tools for open Nokia backup file in PC? I need to view all the contents of my Lumia. Thanks.
Dear Burt,
You can do this by using software called NbuExplorer. It's a NBU backup file viewer and extractor.It supports various backup files' extensions such as nbu, nfb, nfc and arc. It can extract individual files from the backup by drag and drop.
 And it supports these operating systems
Windows 2K / XP / 2003 / Vista / XP X64 / 2008 / Vista64 / 7 / 7 x64
You can download it from here:
http://www.softpedia.com/get/Mobile-Phone-Tools/Nokia/Nokia-NbuExplorer.shtml
If you want to connect your Nokia phone to your computer via USB cable and transfer contents between devices, you need to install the PC software for your phone. You cannot just connect your phone to your computer without the software because there’s no way for the system to identify and access your device.
To connect and access your Nokia Lumia 800 to your computer, download Nokia PC Suite and install. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. Once installed, connect your phone to your computer using the USB cable that came with it. Next, start Nokia PC Suite and that’s it.
With Nokia PC Suite, you can connect your computer to the internet with the help of your phone. You can transfer your personal data like videos, pictures, and other files between your computer and your phone. You can also manage and synchronize your contacts and calendar entries.
