Tools used to import existing users
Hi friends
How do i set up an LDAP?
What are the tools used to import all existing users and groups from our localsystem to LDAP?
Thanks
Hi friends
Thanks
For a detailed process of perfect setup of LDAP, you can visit this website. It serves you better than any other.
https://www.debuntu.org/how-to-set-up-a-ldap-server-and-its-clients/
You can use the LDAPexplorer tool for your LDAP setup. Actually, it makes your way so easy.
LDAPExplorerTool is an aid tool that works as a multiple platform LDAP browser and work also as an editor. You can use it in Windows and Linux OS (operating system).
Its main features can increase your interest-
1. It enables with SSL and TLS support.
2. It serves you the complete UNICODE support.
3. You have the freedom to use it in multi platform.
You can download it from here- https://sourceforge.net/projects/ldaptool/
Also you will learn it's the setup process of the site.
At first you should click on the Directory Service on the Administration window of that program.
Then you will get a check box there, now check mark Use Directory Service (LDAP)
You should choose the information directory of LDAP
Then set up the configuration of that directory feature in LDAP.
Finally select the apply button on that window.
Then you should test this feature and open all the address from your Outlook application or software. Then you should find people form the search option, so click on find people. Then you will get the list of as the basis of your search quarry.
