Hello techyv Experts,
I am looking out for piano applications for my ipad via which i can learn to play piano and even record or sing to my compositions.please list down the top 10 piano sound applications which are user friendly and easy to use.
Folks,make sure the apps do support full MIDI import and export capabilities with studio quality presets
If,you can also provide top 10 amazing piano sounds that will be an add-on.
Top 10 travel piano sound Apps for iPad??
Here is 10 list of piano apps list for ipad
1.50in1 Piano HD
2,Pianist Pro
3.Etude ~ sheet music on steroids
4.Piano! for iPad
5.Twelve Tone
6.ezPiano for iPad: 70+ Songs with Full Accompaniment!
7.PlayItYourself HD
8.Electric Piano for iPad HD
9.Nota for iPad
10.musicalTouch
feature:
• Photorealistic 85 – key keyboard
• 2 keyboard row mode
• Key labels.
Hello McLeod Holcomb,
You can get many piano applications in online. I have researched well and selected 10 best piano applications for you. You can try these.
1) iGrand Piano
2) Virtuoso Piano
3) Pianist
4) Piano Tutor
5) Nota for iPad
6) Piano Complete
7) Duet Piano
8) Ex Piano for iPad
9) Dance Pat Piano
10) Piano! For iPad
These cool features are easy to handle and you can access these iPad Piano from this site:
https://www.apple.com/itunes/
