Top 5 defragmentation softwares for Windows 7
Hello Rsenteciera,
This are the list of top 5 Defragmenter for the year 2011.
1. Diskeeper by Diskeeper Corporation
2. O&O Defrag by O&O Software
3. PerfectDisk by RAXCO Software
4. Norton Utilities by Symantec
5. Puran Defrag by Puran Software
The ranking is based on the Effectiveness, Customer Support, and Ease of Use.
The process of consolidation of fragmented files is called DEFRAGMENTATION.
The necessity of this process creates when after a certain time your data on the hard disk scattered and CPU use more resources to compile the data when you try to retrieve. This happens just because of writing and deleting data day by day.
This may cause the slow behavior of your system. This module is built-in feature in Windows operating Systems. This module rearrange the files and keep them collectively or fragmentally keeping in view, after this process your CPU consumption become down and process time minimized and as a result your system shows quick responses against your instructions.
You can use third party defragmentation tools for this purpose for example
Hope you understand.
CHEERS.
