Dear Techyv Guys, I would like to know your suggestion on top 5 free tools to fix HDD bad sectors.
I am writing a blog on Hard Disk Repair Tool in which I have planned to include top 5 free tools that fix HDD.
So please help me to give your inputs which will be very valuable for me.
Thanks
Top 5 free tools to fix HDD bad sectors
Hi there,
Top 5 free softwares used for repairing bad sectors would be:
HDD Generator, free version – it will go through your HDD, determining if there is any physical damage and helping you in diagnosing the problem with your hard drive. The full version will not only mask bad sectors, but will repair them and make your HDD be as new.
Ariolic Disk Scanner will detect disk read errors which is really important if you don't want to lose any of the data stored on your disk.
Flobo Hard Disk Repair is a simple but functional software that will repair bad errors.
Salvation DATA Bad Sectors Repair will not only repair bad sectors but also give you the opportunity to format it and make partitions once the repairing is done.
DiskPatch is used mostly for repairing the master boot records, corrupt tables and deleted partitions.
All five work great and will be of a great help to every user.
Hi dear,
There are a lot of programs available on the market to remove and fix bad sectors of your hard disk.
I suggest you check out these five tools which are the best for fixing bad sectors.
HDD Regenerator, this tool fixes bad sectors completely and it will not lose your data.
Norton Disk Doctor, this will provide 100% flexibility. It will use your suggestions to remove data from bad sectors.
Maxtor Power Max, this is a powerful utility and very good software. It will erase all data from the hard disk.
Seagate Sea Tool, it will run a diagnostic test on your hard drive and will fix all of the issues, even if they are of bad sectors or partition table.
Partition Table Doctor, this will change your data sectors. It moves data from bad sectors to better ones and block the bad sectors to prevent data.
You can get all this software on Hiren Boot CD, and you can download it from this link.
Hello Garrick,
As well these solutions also you can read another Techyv post where you will get more information about your problem.
Removal for bad sectors in Hard Disk
