simmons
Posted on - 07/02/2019
What are the top 5 software programming languages? Which language is preferred to start with for beginners? Are these languages all different from each other or any of them are similar? Which language is in demand in today’s industry, and why?
Top 5 Software Programming Language
There are lots of software programming languages that are used to develop various software programs, but the most commonly used are:
- Python
- Java
- JavaScript
- C++
- Swift
Python is very easy and usually very interesting for beginners. It does not contain tremendous lines of code for simple functions. Python is interpreted, interactive, object-oriented, and a beginners language. Nowadays all the applications are built with python. YouTube, Instagram, and many more software applications are built on the python framework.
Java is an uncomplicated and strong programming language developed by Sun Microsystems. The main benefit of using Java is that it is platform independent, which means it can run on any platform. Java is naive, secure, robust, dynamic, and supports multithreading. Java is ordinarily used as a backend language.
JavaScript is a dynamic computer programming language. It is usually a part of the web page as it is written in the script tag. It is integrated with Java and also HTML. JavaScript is an open and cross-platform language.
C++ is an object-oriented language; it has the following features: encapsulation, data hiding, inheritance, and polymorphism. C++ is widely used for teaching and research.
Swift is a new programming language used for iOS development. No, all these languages are not similar but a lot different from each other. Python is the best language that can be used for beginners as it is very easy.
