Top five amazing apps for USB key test utility?
Hi All,
I require a list of apps which provide usb drive speed test and health utility for windows 32 bit and 64 bit environment. Kindly,share with me the top five applications for usb key test utility.If the utility can check for both fake capacity and errors it will be an add on.
Answered By 5 points N/A #187227
Here is a list of one of amazing applications for USB flash drive testing:
Check Flash is one of the best application for speed test the USB flash drive and checking errors.
Disk Benchmart have great reviews for measurement of storage performance.
Crystal Disk Mark is a simple benchmark tool and do sequential read-write tests.
HD speed is good software for measurement the speed data transfer on your USB flash drives and also for hard disks.
And for the last Flash Memory Toolkit that have a lot of  features such as: recover format files, erase files, backup functions, measure read or write performance etc.
Williamson Mellisa
