Top softwares and program to read text in the image
OCR software to extract text from images
Can i have few choices and whats best in each of them and steps to get this to work
Hi!
If you want the best and free OCR software in order to extract text from images, here is a recommendation for you. Advanced OCR Free for free.
Advanced OCR Free reads images first when image documents or image papers are being scanned. It then converts them into readable text.
Top softwares and programs to extract text in image are:
1. Google Docs = to use it, one must click on option Convert Text to Google Docs Format. Then, it will perform it's duty. So easy. Have extra specialty compared to others when it has no limit on number of files you want to convert.
2. Abbyy FineReader = recognized as the best in character recognition. Immediately convert PDF files and images into texts. No need to pay for converting a handful of images.
3. OnlineOCR.net = totally good when it comes to quality of converted documents. Has multifunction. Has ability to scan PDF.
4. FreeOCR.com = you don't need to sign up when to use it. Maximum of uploading is 10 images every hour.
5. OCR Terminal = got 20 free conversions per month if you use this software. Can support software screenshots. Quite impressive.
6. OCR Online = capable of converting maximum 100 images per day. Able to use it with many languages.
Here is a comparison between online OCR softwares:
