Topaz 2012 CS6 Plug-in in CS6
I have installed Topaz 2012 CS6 Plug-in in CS6 but is not shown up in CS6,
Please let me know, what may be the reason and get me a solution ASAP.
Thanks in Advance.
Thanks in Advance.
Sometimes the installers do not auto-install into your CS6 Filters menu.
So if your operating system is windows then: Go to the preferences menu, select Plug-ins. Check / enable the Additional Plug-ins Folder option then Choose. After that, Browse: Program Files then Topaz Labs folder and click Choose. And to save this back to Photoshop and click OK and restart your Photoshop. Then you will be able to access Topaz.Â
If your operating system is MAC.
Go to the preferences menu in Photoshop, select Plug-ins. Check / enable the Additional Plug-ins Folder option then Choose. After that, Browse Macintosh HD > Library > Application Support and select the Topaz Labs folder. Then click save / OK to save this back to Photoshop. Back in Photoshop, click OK to save your changes and restart Photoshop and you will be able to access Topaz.
