TortoiseSVN on my work computer with OS of Vista
Hello fellow users,
I have been running the latest stable release of TortoiseSVN on my work computer with OS of Vista, 32bit for some time now, but all of a sudden today almost all of my commits are breaking down (failing mid-commit).
Here are the descriptions in details.
First, I have attempted committing multiple files. I tried to commit a large size of files, over more than 100 and almost 10mb in size. Attempted failed. Afterwards, I kept continuing with smaller portions. Regardless of the size that I made, the commit of those files failed, even when it was down to just 2 small pictures (100kb), or a single xml file.
My internet connection is quite good and there was no interruption during this. Also, I did not find anything faulty with these files, I moved them to my other computer which was able to commit them just fine over the same connection.
I tried to google the problem to find the solution and I found that other svn users (including but not only tortoise svn) are also having this kind of error, but none of the posts had any similar answer to any other post, and all of them were with slightly different situations.
Can you tell me how to get rid of this problem? I really wanted to be able to work from this computer.
Here is the accurate error message shown below:
Commit failed (details follow):
PUT of '<location in svn where file is going>': Could not send request body: An established connection was aborted by the software in your host machine.
Commit – TortoiseSVN Failed
Action Path Mime Type
Command Commit
Adding C:Usersduncamarworkspacemap_repositorytrunkimagesmininwo_imagesgerman_advance.jpg Application/octet-stream
Adding C:Usersduncamarworkspacemap_repositorytrunkimagesmininwo_imagesnwoi.jpg Application/octet-stream
Sending content C:Usersduncamarworkspacemap_repositorytrunkimagesmininwo_imagesgerman_advance.jpg
Sending content C:Usersduncamarworkspacemap_repositorytrunkimagesmininwo_imagesnwoi.jpg
Error Commit failed (details follow):
Error PUT of
Error '/svnroot/tripleamaps/svn/trunk/5100d033e-7ff5-8647-4ed9d50fdo6/trunk/images/mini/cw0_images/nwoi.jpg':
Error Could not send request body: An established connection was aborted by the
Error software in your host mahine.
Error (https://triplemaps.svn.sourceforge.net)
Finished
204 kbytes transferred in 1 minute(s) and 35 second(s)
The operation failed.
OK
