While I was running my Toshiba A200 in recovery disk, my system failed and showed an error. The error was error code 10-fc06-002. I restarted my system a couple of times but the problem persisted.
I tried to look for the problem and its solution to no avail. If you have any idea about the problem I am having and its possible solution, then please let me know.
Toshiba A200 system failure during recovery
Hello Branddon, this look like a serious operating system problem. Something have gone wrong with your start up files on your hard drive. You have not explain which operating system you are using on your Toshiba A200 so i am guessing it is a windows OS. So my advice to you is to:
1) Back up all your information on your hard drive.
2) Then do a full format of the hard drive.
3) Then reinstall a operating system.
If you need any help with how to back up your hard drive please feel free to ask me.
Thanks!
