Another IceCream Sandwich (ICS), AT300 Tablet with Tegra 3, has been launched by Toshiba. Went through the features. I'm not clear about the upgrade process of internal storage. Can anyone help with it?
Toshiba: AT300 Tablet with Tegra 3, Ice Cream Sandwich
Hi Berthapearll,
It is nice to know that you are interested in the Toshiba AT300 tablet. The Toshiba AT300 will come in 2 variants, one with a 16GB internal memory and the other with a 32GB internal memory. Both will come with a Micro SD slot and a standard SD slot. The SD slots will provide both models the capability to expand the storage space. It is a little bit different from the traditional computers from the market wherein you can literally upgrade the system memory.
By the way, the AT300 Toshiba tablet will first be released in Japan at around 700 US dollars.
I hope I was able to answer your question!
Paul Pinalb
The Toshiba Thrive is a 3G tablet operating on 2G and 3G network bands using GSM and HSPA technologies. This is a discontinued tablet and is no longer being manufactured. It was announced to the public on June 2010 and released on July 2011. It measures 273 x 177 x 16 millimeters and weighs 725 grams. It uses a mini-SIM card.
It has an IPS LCD capacitive touchscreen display with 16M colors at 1280 x 800 pixels screen resolution and supports multi-touch. It runs on Android 3.0 Honeycomb upgradable to Android 3.2 Honeycomb powered by NIVIDIA Tegra 2 T20 chipset, Dual Core 1.0 GHz Cortex-A9 processor, and ULP GeForce GPU. It supports an SD card expandable up to 32 GB.
It runs on 1 GB RAM with internal storage available in the following capacities: 8 GB, 16 GB, and 32 GB. The primary camera supports 5 megapixels with autofocus support and can record videos. The secondary camera supports 2 megapixels. It has 3.5-millimeter jack; Wi-Fi 802.11 b/g/n with hotspot support; Bluetooth; GPS with A-GPS support; miniUSB 2.0; and USB 2.0.
It has built-in accelerometer, compass, and gyro sensors. The pre-installed web browser supports HTML5 with Adobe Flash support. Java is supported through Java MIDP emulator. It runs on non-removable Li-Ion battery with talk time up to 7 hours. It is available in black color.
