Toshiba Bluetooth Configuration Error – FATAL ERROR: Registry Load Failure
Hello guys.
I found a problem after installing the software.
I receive the following error message when I click on the "wwigo video" button:
Toshiba Bluetooth Configuration Error – Refer to HELP
I press OK and a new error message appears
I re-press OK and the following message appears
Previewing Failed !!!
Last of all these no communication is happened with my N95 which can make a connection via Bluetooth with my Toshiba laptop.
What is the wrong?
I am using Windows XP SP2 and I have the Bluetooth Stack of Toshiba…
The PC.log file contains the following
Error: Cannot start graph
Help needed. Thanks in earlier.
