Toshiba laptops trusted computer brands
Toshiba laptops is one of the trusted computer brands.
Is there any new Toshiba laptops units with new features?Â
Q.Toshiba laptops is one of the trusted computer brands. Is there any new Toshiba laptops units with new features?Â
Yes, there are various new Toshiba laptops with new features. Most of the features upgraded are the processing speed, weight, RAM, CPU frequency and weight.
Not all utilities are available for every model
Below are some specifications of Toshiba laptops 2012;
Toshiba Satellite A300 – 22W  Â
Specification
Pentium 2000 MHz/15.4 in/3072 Mb/320 Gb/DVD-RW Type Laptop Length 14.2 inch (362 mm) Width 10.5 inch (267 mm) Height 1.5 inch (38.5 mm) Weight 6 lbs (2.7 kg) OS provided Win Vista Home Premium PROCESSOR CPU Pentium CPU Frequency 2000 Mhz CPU Code T4200 Number of Cores 2 L2 Cache 1 Mb Data Bus Speed 800 MHz RAM Installed RAM 3072 Mb Memory Type DDR2 800 MHz Maximum RAM 8192 Mb RAM Slots.
Toshiba Satellite A300-234
Specification
  Core 2 Duo 2000 MHz/15.4 in/2048 Mb/320 Gb/DVD-RW Type Laptop Length 14.2 inch (362 mm) Width 10.5 inch (267 mm) Height 1.5 inch (38.5 mm) Weight 6 lbs (2.7 kg) OS provided Win Vista Home Premium PROCESSOR CPU Core 2 Duo CPU Frequency 2000 Mhz CPU Code T6400 Number of Cores 2 L2 Cache 2 Mb Data Bus Speed 800 MHz RAM Installed RAM 2048 Mb Memory Type DDR2 800 MHz Maximum RAM 8192 Mb .
Toshiba Satellite A300-243
 Specification
 Configuration Core 2 Duo 2000 MHz/15.4 in/4096 Mb/250 Gb/DVD-RW Type Laptop Length 14.2 inch (362 mm) Width 10.5 inch (267 mm) Height 1.5 inch (38.5 mm) Weight 6 lbs (2.7 kg) OS provided Win Vista Home Premium PROCESSOR CPU Core 2 Duo CPU Frequency 2000 Mhz CPU Code T6400 Number of Cores 2 L2 Cache 2 Mb Data Bus Speed 800 MHz RAM Installed RAM 4096 Mb Memory Type DDR2 800 MHz Maximum RAM 8192 Mb
 Toshiba Satellite  A300-23T
 Specification
Toshiba Satellite PRO L350-S1001X
 Specification
Core 2 Duo 2100 MHz/17 in/2048 Mb/160 Gb/DVD-RW Type Laptop Length 15.6 inch (398.7 mm) Width 11.5 inch (292.1 mm) Height 1.7 inch (43.1 mm) Weight 7.1 lbs (3.2 kg) OS provided WinXP Prof PROCESSOR CPU Core 2 Duo CPU Frequency 2100 Mhz CPU Code T8100 Number of Cores 2 L2 Cache 3 Mb Data Bus Speed 800 MHz RAM Installed RAM 2048 Mb Memory Type DDR2 667 MHz Maximum RAM 4096 Mb RAM Slots…
Toshiba Satellite A300-248
 Specification
 Core 2 Duo 2000 MHz/15.4 in/4096 Mb/320 Gb/DVD-RW Type Laptop Length 14.2 inch (362 mm) Width 10.5 inch (267 mm) Height 1.5 inch (38.5 mm) Weight 6 lbs (2.7 kg) OS provided Win Vista Home Premium PROCESSOR CPU Core 2 Duo CPU Frequency 2000 Mhz CPU Code T6400 Number of Cores 2 L2 Cache 2 Mb Data Bus Speed 800 MHz RAM Installed RAM 4096 Mb Memory Type DDR2 800 MHz Maximum RAM 8192 Mb.
Toshiba Satellite A300-22WÂ Â
Specification
Toshiba SAatellite A300-234 Â
Specification
Toshiba Satellite L300D-20M Â
Specification
Athlon X2 2100 MHz/15.4 in/2048 Mb/250 Gb/DVD-RW Type Laptop Length 14.2 inch (362 mm) Width 10.5 inch (267 mm) Height 1.5 inch (37.7 mm) Weight 5.3 lbs (2.4 kg) OS provided Win Vista Home Premium PROCESSOR CPU Athlon X2 CPU Frequency 2100 Mhz CPU Code QL-64 Number of Cores 2 L2 Cache 1 Mb RAM Installed RAM 2048 Mb Memory Type DDR2 800 MHz Maximum RAM 8192 Mb RAM Slots 2
Hello friend,
Toshiba laptops are one of the top laptop brands in the world.
Toshiba laptops have their trademark on reliability and its toughness.
Toshiba have lots of new laptops releasing in every month.
In international laptops once the Toshiba get on the number one position. As the world wide laptop users say it is one of the laptop's ever.
Toshiba's new Satellite U845W is being a revolutionary step in Toshiba's history.
Its main features are as follows :
All the above features make the new Toshiba Satellite U845W a unique laptop.
It is still running in stores successfully. It is an upgraded version which have lots of unique functions.
I hope you get the answer.
Have a nice day.
Hello Azreil Balthazar,
Thank you for that interesting question. You are asking about new Toshiba brands in the market.
Well, there are many new Toshiba laptops launched in the market.
The following are the laptops that I highly recommend to you:
1. Toshiba Satellite P755-3dV20
2. Toshiba Qosmio X775
3. Toshiba satellite A665
4. Toshiba Satellite T135
5. Toshiba Satellite E205
Just choose any of those Toshiba laptops and hope this helps.
