Toshiba recovery disk tutorial needed
Asked By 130 points N/A Posted on -
Hi guys, I am using Toshiba S1120, recently my hard disk was affected by malware. It deleted most of my data. Tell me the website for online Toshiba recovery disk tutorial. I searched in many websites there is no useful information regarding this. You Guys, please help me to get back my data. Thanks
Best Answer by Ropp Watson
Answered By 5 points N/A #193442
You need to use data recovery software for this purpose. You can salvage your data from wherever required. You might need two CDs for this purpose. If you have two disks then in that case you can insert one CD into one disk and the other CD into the other disk. After that you will see the boot screen, then press R. You can format the CD with the help of keyword 'F'. Finally insert the other CD and click Restart. Your required task will be done.
Waters Magner
Answered By 0 points N/A #193440
This are some of the things you need to do in order to recover your data from you're Toshiba S1120. First of all, make sure that you've made a back-up File Folder wherein, you'll be saving all the data that is important to.
I assume you have 2 CD's from purchasing your unit. Insert the first CD to the disk driver and turn the unit off then on afterwards. As soon as the system resumes, then you'll see a Boot screen. Press the key "R" to recover your data and "F" to format your hard ware. Then, insert the second CD when prompted. Then after completing the process, select "Restart". Allowing this will assure that the Windows application can be started
