Toshiba Warranty Check: How do I do It?
I recently bought a Toshiba Satellite Pro C651 laptop which I need to check it's warranty online. Where do I check the serial number and which is the url to a site I need to do this? How will I check the information and how can I know whether the warranty has expired?
Answered By 0 points N/A #181578
You can know toshiba serial number or model number on the down side of your laptop as shown in the image.
Once you know your serial number and model number click on TOSHIBA. This will direct to the link where you need to input serial number and model number and it will show you the warranty details check date of expiry of warranty and you will know if warranty has expired.
Even you can know your laptop warranty details on your bill. Mostly it is 1 year warranty from the date of purchase unless you have bought extended warranty at the time of buying. Even on the bill the warranty expiry date is written you can check there as well.
