I need a safe and easy to use privacy protection tool, that will ensure the advanced information removal solution and thereby protecting from Online and Offline Threats. It should ensure clear Privacy of the data being used. My friend told me to use Total Privacy 5. will that help, please advise me on where to download the premium version of that.
Total Privacy 5 (advanced information removal solution)
Hello
You can find free and pro vesions of Total Security 5 on this link: https://www.pointstone.com/products/TotalPrivacy/
If you want pro version then you have to pay. This application supports all internet browsers to ensure best internet safety, also it have options to delete data so your data is unrecoverable by some other application for stealing data, it protects your e-mails and it have over 450 plugins which you can use to customize level of security. I hope I helped. Regards.
